Multisim and Ultiboard
Help working with a Spice model in MultiSim?
I have a spice model (txt) of an NMOS I'm trying to bring into MultiSim (file is attached).  I have never worked with spice models before, so this is a first for me.
I followed the instructions I found here:
http://digital.ni.com/public.nsf/allkb/85281067A82F9DE186257AEF00654728
However, I have a few questions:
1.  I only need the NMOS.  So I copied everything from the top of the file until:
****************not used +CBD    =0.000e+00 CBS    =0.000e+00 IS     =0.000e+00
+MJ     =3.400e-01 N      =1.000e+00 MJSW   =2.300e-01
+PB     =6.900e-01 TT     =0.000e+00
+PBSW   =6.900e-01
I did NOT copy this part:
.subckt PM D G S B
+params: W=10u L=1u
M1 D G S B PM L={L} W={W} AS={2u*W} PS={2*(2u+W)} AD={2u*W} PD={2*(2u+W)}
.ends
Was that correct?  Or does that section still belong to the NMOS device?
2.  As part of the import process, I was supposed to verify the pin order.  But I had no way of knowing for certain whether the pin order was correct or not.  I used the virtual model, and it had a line of text rather than the table my imported component had.  How can I tell what the correct pin order is?  And what's the best way to correct it now?  Should I just delete the component from the User DB and start over?
3.  Once I place an instance of this component on the schematic, how do I edit the gate length and width?  Specifically for just that instance, because I will place several of these, and they won't all have the same length and width.
Thanks!
(5,833 Views)
Hi Doven,
1.  You are correct, the "PBSW" is the last parameter defined in this NMOS model.
+PBSW   =6.900e-01
2.  You can look up the NMOS in a SPICE manual it will tell you the pin out.  If you look at the PMOS model in the text file, you can tell the pin order from the sub-circuit statement.  Pin order starts from left to right, so D is pin 1.
.subckt PM D G S B
3.  If you want to add length and width to the model, create a sub-ciruit similar to the PMOS model in the text file. You need to add these lines:
.subckt NM D G S B
M1 D G S B NM L=0.001 W=0.001
* Paste the NMOS model betwen these lines.
.ends NM
Tien P.
(5,816 Views)
Hi how do i correct this.
i copy the same schmatic file that the spice file is attached
SEE ATTACHED
(1,461 Views)
