03-23-2011 02:23 PM
Hi
We are using the ALD1106 and the ALD1107 MOSFET array chips to learn about current mirrors and differential amp.
The chip has one pin for the bulk, and I can't get correct configuration to create the chip.
We've got the SPICE parameters from ALD in one *.lib file.
I've created the ALD1106 and it got problems...
Any idea how can I make them both work?
P.S.. I've attached the *.lib as txt file and the chip model.
05-02-2011 10:55 AM
Can you please explain what problem you got?
Here is also a great tutorial on how to creat a new component.
http://zone.ni.com/devzone/cda/tut/p/id/3173
Leila Feyz,
05-08-2011 11:56 AM
I've tried to follow the tutorial and I've failed to create the chip.
I think that my big problem is that I don't understand the SPICE param. that I got.
And what to do with common pins. Do I need to connect them to the same pin? Do I need to omit them (to create 3 pin FET)?
Moses
05-10-2011 09:19 AM
Hi Moses,
A .lib file is a library, it has multiple SPICE models in the same file and you have to copy only the model you want to simulate and create a component from that. Here are the models you mentioned:
This is the 1106 model:
07-17-2011 02:54 AM
I did so, and the result is an error...
I've attached a doc with my steps.
P.S.. Sorry for the late response.
Moses
07-19-2011 08:59 AM
Hi Moses,
The last time I looked at the 1106 and 1107 model, I didn't see that they are calling another model called ncg and pcg respectively. I looked at the .lib file you originally posted and didn't see these models in the library file so this library file is incomplete. Where did you get this file?
07-19-2011 09:30 AM
My lecturer got it from ALD and mailed me the contant of the ic_mod.lib file.
Thats is the original data from the mail:
* Library of Advanced Linear Devices, Inc. definitions
* Copyright 2004 Advanced Linear Devices, Inc.
* Neither this library nor any part may be copied without the express
* written consent of Advanced Linear Devices, Inc.
* PSPICE version
* $Revision: 1.3 $
* $Date: 6 Feb 2004 00:00:00 $
* This library of models and macromodels is being supplied to users as an aid to
* circuit design. While it reflects reasonably close similarity to the actual device
* in terms of performance, it is not suggested as a replacement for bread-
* boarding. Simulation should be used as a forerunner or a supplement to
* traditional lab testing.
* Users should very carefully note the following factors regarding these
* models:
* Model performance in general will reflect typical baseline specs for a
* given device, and certain aspects of performance may not be modeled
* fully.
* While reasonable care has been taken in their preparation, we cannot be
* responsible for correct application on any and all computer systems.
* In all cases, the current data sheet information for a given real device
* is your final design guideline, and is the only actual performance
* guarantee. For further technical information, refer to individual device
* data sheets.
* Model users are hereby notified that these models are supplied "as is",
* with no direct or implied responsibility on the part of Advanced Linear
* Devices for their operation within a customer circuit or system. Further,
* ALD reserves the right to change these models without prior notice.
* The macromodels listed in this library represent typical performance
* characteristics, without offset (Vos) adjustment, or other
* parameters that would allow for Monte Carlo simulation of these circuits.
* Advanced Linear Devices provides a separate library of ASIC standard cell
* functions such as operational amplifiers, timers, and comparators as well
* as resistors, capacitors, and individual transistors and diodes for func-
* tion specific integrated circuit design. This ASIC verification library
* contains a comprehensive set of parametric values to be used in Monte
* Carlo simulation of user designed integrated circuits. Contact your
* Advanced Linear Devices representative for more information.
* Your feedback and suggestions on these (and future) models will be
* appreciated.
* Advanced Linear Devices, Inc.
* Customer Support Group
* 415 Tasman Drive
* Sunnyvale, California. 94089
* Tel: (408) 747-1155
* Fax: (408) 747-1286
* techsupport@aldinc.com
* IC_MOD.LIB
* ALD ANALOG MODELS FOR IC MOSFETS IN IC_TRAN.LIB
* Last Updated Date: 2/6/04 BY:RLC
* SPICE MODELS FOR COMPARISON: ADVANCED USERS
* These models have been fitted to the ALD device structures.
* For short channel or "digital" transistors, use the digital library transistor models in id_trans.lib.
* N-channel TRANSISTOR models
* Listing of 1101 transistor models:
* --nca 2mv ultra precision matched transistor model. (ALD1101A)
* --ncg general purpose transistor model. (ALD1101)
* Four terminal integrated N-channel ( 2mv. vos dist)
.model nca nmos (Level=2
+ gamma=1.09 lot/4/uniform=-.22 dev/uniform=.01
+ vto={.75+vtn} lot/2/uniform=.2 dev/uniform=1e-3
+ Uo=650 lot/3/uniform=40 dev/uniform=.5
+ Ucrit=0.7e4 Uexp=.1 Vmax=1.6e5
+ phi=.70 tpg=+1
+ nsub={1e16*ires} neff={10*ires} nss=.7e11 nfs=1.17e11
+ tox={.055u*cox} lot/8/uniform=9.1% dev/uniform=.05%
+ Cgso={.94n*cox} Cgdo={.59n*cox} Cgbo={.138n*pox} Xqc=.42
+ cj=.39m mj=.5 cjsw=264p mjsw=0.18
+ xj=2.0u
+ ld=1.6u lot/uniform=.19u dev/uniform=.15u
+ wd=1.05u lot/uniform=.41u dev/uniform=.1u
+ pb=.9 js=20.u lot/uniform=50% dev/uniform=80%
+ jssw=2.07e-10 lot/uniform=50% dev/uniform=80%
+ kf=.75e-28 rsh=10 lot/1/uniform=4 dev/uniform=.5)
* 1101 instances use: nrd=.03 nrs=.02 nrg=25 nrb=35 for big devices.
* Package model devices -four terminal integrated N-channel @ vbs=0, grade: a, vos=2.0mv worse case
* mismatch no MC.
* Four terminal integrated N-channel (.040 vos dist).
.model ncg nmos (level=2
+ gamma=1.09 lot/4/uniform=-.22 dev/uniform=.04
+ vto={.750+vtn} lot/2/uniform=.2 dev/uniform=19e-3
+ Uo=650 lot/3/uniform=40 dev/uniform=5
+ phi=.70 tpg=+1
+ cj=.39m cjsw=264p
+ xj=2.0u
+ ld=1.6u lot/uniform=.19 dev/uniform=.02
+ wd=1.05u lot/uniform=.42 dev/uniform=.1
+ pb=.9 js=20e-6 mj=.5 mjsw=0.18
* P-channel TRANSISTOR models
* Listing of 1102 transistor models:
* --pca 2mv ultra precision matched transistor model.
* --pcg general purpose transistor model.
* Four terminal integrated P-channel ( 2mv. vos dist)
.model pca pmos (level=2
+ vto={-.74+vtp} lot/5/uniform=.2 dev/uniform=1e-3
+ gamma=.58 lot/7/uniform=.2 dev/uniform=.01
+ Uo=260 lot/6/uniform=20 dev/uniform=.6
+ Ucrit=1.0e4 Uexp=.16 Vmax=3.0e5
+ phi=.70 tpg=-1
+ nsub=1e16 Neff=1 nss=1e11 nfs=1.06e11
+ Cgso={.61n*cox} Cgdo={.39n*cox} Cgbo=.138n Xqc=.42
+ cj=.18m cjsw=322p
+ xj=1.2u ld=.96u wd=.5u pb=.9 mj=.57 mjsw=0.33
+ js=20e-6 lot/uniform=50% dev/uniform=80%
+ kf=.75e-28 rsh=90 lot/9/uniform=20 dev/uniform=4)
* Four terminal integrated P-channel ( 40mv. vos dist)
.model pcg pmos (level=2
+ vto={-.74+vtp} lot/5/uniform=.2 dev/uniform=19e-3
+ gamma=.58 lot/7/uniform=.2 dev/uniform=.03
+ Uo=260 lot/6/uniform=20 dev/uniform=.5
+ phi=.70 tpg=-1
+ tox={.055u*cox} lot/8/uniform=10% dev/uniform=.05%
+ Cgso={.31n*cox} Cgdo={.39n*cox} Cgbo=.138n Xqc=.42
+ cj=.18m cjsw=322p
+ xj=1.2u ld=.96u wd=.5u pb=.9 js=20e-6 mj=.57 mjsw=0.33
08-20-2011 01:53 PM
OK
I got the original file from ALD.
The ic_mod file has a line with .ncg...
02-06-2017 12:53 PM
I'm also trying to add the ALD1106 but am having problems. When I go in to add the multiple sections I try to add 4 pins per section so that on the schematic each section will have the 4 pins for the mosfet configuration. When I do this it tells me that the Symbol Pin names can't be the same, and when I make them different it tells me that I can't connect pins with different names to the same pin. Am I missing something here that you could easily touch on?
