Multisim and Ultiboard
Help : time step too small
I have a simple bridge rectifier circuit, however, when I tried to get the output using an oscilloscope, it gives me a message that time step too small.
Any help will be appreciated.
I have attached the circuit. Very simple circuit.
Thank you
(5,321 Views)
Hi okogidi,
Try doing the following changes in the Simulate menu:
Simulate>>Interactive Simulation Settings, change the Maximum time step (TMAX) to: 1e-003.
 Then go to the Analysis Options tab, SPICE Options>>Use Customs Settings>>Customize; in the Global tab change the Relative error tolerance (RELTOL) to 0.01.  Ok, Ok... and now run the simulation.
Let me know how it works,
Fernando, NI
Message Edited by Fernando DZ on 10-04-2007 12:01 PM
Fernando D.
(5,304 Views)
Solution found: Place a ground on the bridge rectifier where it attaches to your 1K resistor on Pin 4. This should cure the problem.
I hope this solves your situation.
Have A Nice Day
Message Edited by lacy on 10-04-2007 01:04 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(5,302 Views)
Hi Fernando. Just so you'll know the only thing needed here is a ground on the bridge and it will simulate with his current settings.
Have A Nice Day
Have a Nice Day
(5,294 Views)
Hi lacy,  I tried using the Convergence Assistant, but yes, the circuit was needing that ground.
Thanks!
Fernando
Fernando D.
(5,287 Views)
Thank you everyone. It worked perfectly.
(5,279 Views)
