10-04-2007 10:13 AM
10-04-2007 12:59 PM - edited 10-04-2007 12:59 PM
Hi okogidi,
Try doing the following changes in the Simulate menu:
Simulate>>Interactive Simulation Settings, change the Maximum time step (TMAX) to: 1e-003.
Then go to the Analysis Options tab, SPICE Options>>Use Customs Settings>>Customize; in the Global tab change the Relative error tolerance (RELTOL) to 0.01. Ok, Ok... and now run the simulation.
Let me know how it works,
Fernando, NI
Message Edited by Fernando DZ on 10-04-2007 12:01 PM
10-04-2007 01:02 PM - edited 10-04-2007 01:02 PM
Solution found: Place a ground on the bridge rectifier where it attaches to your 1K resistor on Pin 4. This should cure the problem.
I hope this solves your situation.
Have A Nice Day
Message Edited by lacy on 10-04-2007 01:04 PM
10-04-2007 01:13 PM
Hi Fernando. Just so you'll know the only thing needed here is a ground on the bridge and it will simulate with his current settings.
Have A Nice Day
10-04-2007 01:26 PM
10-04-2007 01:53 PM
