04-21-2011 11:37 AM
The class as well as my teacher can not figure out how to activate the 7 segment LED in the mode 10 counter attached to this post. The attachment is the entire ckt from multisim version 10.1 (student).
I am at a loss :(.
04-25-2011 08:05 AM
Could you attach the Multisim file (*.ms10) for troubleshooting?
04-25-2011 09:21 AM
Thank you for pointing out that the attachent was not for multisim. The multisim ckt is attached to this post.
Thank you for the assistance and if you have any other questions, let me know.
Kevin
04-25-2011 10:50 AM
Hi Kevin,
Here are some suggestions:
Attached is your circuit with these modifications.
Hope this helps.
Fernando
11-25-2011 11:01 AM
i wolud realy appreciate if you could help me find what is wrong in this circuit!!
11-25-2011 03:54 PM
There are two basic problems with the ciecuit:
1- The display and the 74LS IC work with 5v
2- Floating inputs on IC's are never good. When the switches on the 74LS47 are open, the IC's inputs are floating. The switched inputs need to be tied to +5 through pull up resistors.
See your circuit with the fixes attached.
11-25-2011 11:00 PM
can you upload this file using multisim 10??because i don't have mutisim 11!!
11-26-2011 12:54 AM - edited 11-26-2011 12:55 AM
I have built a seven segment display circuit using nand gates.The i cannot get the Display to lit!!pleaaase help me!!(multisim 10.0)
11-26-2011 09:33 AM
Sorry, but I have no way to convert to Multisim 10. If you follow my written suggestions, you should be OK.
11-27-2011 12:25 AM
Hey i hVE an elecronics question,Which technology is better for the LCD technology TTL or CMOS??explain why??
