07-11-2011 04:19 PM
Sorry if this question has been answered, but I can't seem to find it anywhere.
I'm attempting to install Circuit Design Suite 11.0 on my Mac using Parallels (Windows 7). Whenever I try to run the setup file, it starts, but also gives me an error that reads:
"Fatal Error!! Required NIPathsDir property CDS110DIR is undefined."
I can't seem to get past this step and I have tried googling everything related to this to no avail. If anyone has multisim running on Parallels, could you impart some insight?
Thank you and let me know if you need any further information from me.
Solved! Go to Solution.
07-11-2011 09:35 PM
I have found the solution to this problem, in case anyone else has this issue in the future. It seems that the issue was that I was sharing my Mac OS X folders with windows. Apparently, if the folders inside of your Windows target a network folder, there are issues with installing multisim. The fix is as follows: Click the red parallels button at the top right of the screen, go to Devices, Sharing, and then uncheck "Share Mac OS X folders with Windows". Worked like a charm after that.
10-05-2011 05:13 AM
Hii I am trying to install the multisim and ultiboard student edition .But the installer pops out an error saying" fatal error!! Required NIPathsDir property CDS110DIR is undefined.is there any available fix to this ??Please help me .....Thanks
10-06-2011 08:44 AM
Hi techguru,
Did you try the solution which is mentioned in the previous post. It should work.
10-06-2011 09:07 AM
10-06-2011 09:30 AM
10-06-2011 10:04 AM - edited 10-06-2011 10:10 AM
