Multisim and Ultiboard
Error when trying to insert bitmap file
Hello!
I have a problem with the symbol editor in Multisim 11.  When I'm trying to insert a bitmap file the whole programm crashes.
I would like to have the actual Opamp symbol in multisim. See: http://commons.wikimedia.org/wiki/File:Normsymbol_OPV.svg
How can I do this?
Thanks!
mikcon
(5,685 Views)
Accepted by mikcon
Hi Mikcon,
I install  Multisim 11.0 take your Symbol and resize it and saved it as a bitmap.
Then I opened the Component Wizard and try to create a new Component with your OPV Symbol and everything works fine without any errors or crashes.
Here some Screenshots for you:
So most likely your Multisim Installation is corrupted.
Please try to repair your Multisim and test this issue again.
Kind Regards,
Oleg Scherling, M.Eng | Applications Engineering | National Instruments | NIG |
(5,647 Views)
Thank you very much for your help Oleg!
I found that the problem was, that my image was still to big, though I resized it. Now it works.
When the images are to big then Multisim crashes.
best regards
mikcon
(5,639 Views)
Hi Mikcon,
I'm glad to hear that you could solve the Problem.
To complet the Request please mark it as "Resolved".
I wish you much success with your Project.
Kind Regards,
(5,635 Views)
