11-18-2012 10:52 AM - modificato 11-18-2012 10:56 AM
I very bad know English, but i will try explain my problem ;). .I have problem with a new component .
I must create simple component - Cmos inverter (source-5v) . But I'm confused in Component Wizard and always have a 4-6 errors =(. I need an example.
Thx,guys!
in data 11-19-2012 07:53 AM
I tried it out on MS12 and it worked fine, not sure what more I can tell you.
in data 11-19-2012 09:18 AM
The component MODEL is text representing the simulation data of a component. This is written in the SPICE language. You need this model for simulation to work in Multisim. Wihtou it, you'll only cvreate a layout and footprint component, no simulation. You can learn this language and create your own components, or you can find premade ones online by manufacturers of components (like TI, NS, AD, etc...). You can also copy the model from an already available component that is similar to what you want. Hope this helps.
Cheers,
