Multisim and Ultiboard
Convergence error
I'm trying to simulate a TDA2030 amplifier with splitted power supply but I'm getting convergence error in Multisim.
What is that I'm doing wrong?
(5,661 Views)
I had the same problem here, too, but it was due to the ground. Try to check it if that is the case
(5,646 Views)
Can't find any problem with ground...
Maybe that the spice model doesn't work with a splitted PS?
Was there a splitted PS in your circuit?
(5,637 Views)
Use the auto-resolve conflicts. Maybe the set of initial parameters is wrong.
(5,584 Views)
You're not doing anything wrong.  It's a Multisim issue that can be fixed by doing the following (please let me know if it works for you):
Simulate Tab (Alt + S), then Interactive Simulation Setting (n), then change “Initial Conditions:”
From the default "Determine Automatically" to "Set to zero".
(5,411 Views)
