Multisim and Ultiboard
取消
显示结果
搜索替代
您的意思是:
Connectivity Errors
Am still trying to design my first PCB using Multisim and Ultiboard.  I have transfered my Design from Multisim onto Ultiboard, and also placed my parts manually.
However, when I run Connectivity checks in Ultiboard, it gives me 34 errors.  Attached is just a small capture of the error list, and smal section of my layout.  I can't figure out what to do to take care of the connectivity errors.
Anyone knows what I can do to fix such connectivity errors?  Meanwhile, I didn't change any settings on Ultiboard, but used all the default settings.
I would appreciate any suggestion.
0 项奖励
1 条消息(共 3 条)
4,732 次查看
Hi Tebefia,
Some times if when you create your PCB desgins it happens that you will get the connectivity errors, here you can find some documentation that hopefully will be helpful for you to identify the possible root causes for your errors.
Solving Trace/Via Errors in a Connectivity Test in Ultiboard
Best Practices in PCB Design: Routing
Sil.VI
0 项奖励
2 条消息(共 3 条)
4,712 次查看
A connectivity error just means that you haven placed a track between two pins of parts...
So you still have 18 tracks to place...
succes!
0 项奖励
3 条消息(共 3 条)
4,703 次查看
