10-14-2011 03:01 PM
I was wondering, how can I find Capacitance and Conductance measurments.
I have a circuit with a resistor (100kohms), a capacitor (1microF), and AC current 1VAC.
I have to find the capacitance and conductance at 200+ frequencies. (e.g. 5 Hz, 10 Hz, 20 Hz, 30 Hz, 40 Hz, 50 Hz, ......... ect.)
I put together the circuit but but have no idea what i should use to find these measurments.
Please help!
thanks
10-14-2011 08:33 PM
Undergrad,
I am assuming that you want to measure the overall complex impedance over these frequencies (resistance, reactance) - this you can measure.
This can be expressed as magnitude and phase (A) or as a complex number (B)...
(A) Z = |Z|e^ (j(theta))
(B) Z = R + jX
You can use simple math to convert (A) into (B) and vice versa...
There are several ways to do measure this in Multisim. I would check out one of the 2 ways.
1. Using AC Analysis Sweep
from the Multisim menu Simulate -> Analyses -> AC Analysis
If you measure the voltage across the AC current source in your circuit, the voltage measurement will be the complex impedance in Magnitude / Phase form.
Here is a result from a simple RC circuit.
2. You can also use the Impedance Meter instrument (Multisim v11)...
from the menu, Simulate -> Instruments -> LabVIEW Instruments -> Impedance Meter
Take out the AC current source and wire the instrument (+/-) across the nodes. The measurement shows the impedance as Resistance (R), Reactance (X) and the magnitude |Z|.
Here is the readout in the same RC circuit.
In this form, the complex impedance at a certain frequency Z = R + jX
Note that the |Z| readout at F=10 Hz on the meter and the cursor showing magnitude (|Z|) at 10Hz on the previous AC sweep closely match.
Pat Noonan
10-17-2011 02:11 PM - edited 10-17-2011 02:14 PM
Thanks for you responce, but i dont think thats what i was looking for.
I have a R-C parallel circuit with its resistance 100kohms and its capacitor 1microF. My AC current is 1 VAC.
from this i simply need to find my capacitance measurments and conductance measurments at various frequencies.
If someone could tell me what Instrument I could use or something to find these measurments that would be great.
thanks again.
Attached i have a file that shows you my circuit
