Multisim and Ultiboard
8052 assembler not working
Hello everyone,
When trying to build, an assembler code for the 8052 I get this error:
main.asm
Errors: main.asm
No listing file generated by assembler. (Invalid $INCLUDE directive? Semi-colon after $MOD directive?)
Assembler results: 1 - Errors, 0 - Warnings
The code is correct because it works fine in other devices, I already tried unistaling and installing again Multisim with no result.
Anybody has an idea on how to solve it?
Thanks in advance.
PS: In case is useful, im pasting the code here.
$MOD52  ; This includes 8052 definitions for the Metalink assembler
; Please insert your code here.
ORG 0000H
ORG 0033H
INICIO: CLR P2.0
SETB 20H.0 SALTO1: NOP
NOP
NOP
JB P1.0, SALTO1
JB 20H.0, APAGAR
CLR P2.0
SETB 20H.0
JMP SALTO1
APAGAR: SETB P2.0
CLR 20H.0
JMP SALTO1
END
(1,958 Views)
Hi Carmyex,
First I have to make a remark that the error message is about two ASSEMBLER CONTROLS/DIRECTIVES ($INCLUDE and $MOD) but combined in only one error count.
There is no $INCLUDE assembler control/directive in the code that you posted. If you missed copying some parts of your code, you can insert it in your reply. On the other hand, it is also possible that the "Invalid $INCLUDE directive?" message was just induced by the "$MOD" assembler control/directive.
The main problem that I can infer from your post is that the code is written for the MetaLink Cross Assembler but the Development / Code Generation Tools that you are using employs a different assembler. The Metalink Cross Assembler does not classify $INCLUDE and $MOD52 as part of its ASSEMBLER DIRECTIVES (e.g., ORG, EQU). Instead, $INCLUDE and $MOD52 are part of Metalink's ASSEMBLER CONTROLS. Notice that the error message used the term directive for $INCLUDE and $MOD.
Try replacing the line
with
$MOD52
If the assembler still issues errors about this line, comment out the line containing the $MOD52 assembler control/directive
from
to
;$MOD52 ; This includes 8052 definitions for the Metalink assembler
Your code might be successfully assembled without the need for the $MOD52 control/directive especially if you are using a newer Development / Code Generation Tools.
G. Goodwin
(1,806 Views)
