04-16-2020 04:57 PM
On MultiSim Live Premium I can find a 7-segment display. What I can't find is a display driver (binary in, display out) or the kind of 7-segment display simulator where you put the binary in and you get the decimal number displayed.
04-17-2020 06:12 AM
Hi MrWiedorn,
It looks like, for digital components, only logic gates and latches/flip-flops are currently available. If this page Help >> Components is up-to-date, more complex logic function module such as seven-segment display decoder/driver is not yet available in Multisim Live.
G. Goodwin
04-17-2020 07:28 AM
I forgot that you can try searching through the components, perhaps, for specific part numbers such as 74LS47, 74LS48, 74LS49, etc. A Components table can be found in this page, Pricing >> Tier Details. The table has an entry for 10 LED drivers. I don't know if this includes seven-segment display decoders/drivers.
04-17-2020 02:10 PM
I too am unable to fine the 74ls47 display driver (or anything comparable)...As a work around you can use LED's and arrange them in the proper binary order, then slow the Voltage clock down and you can see the display in binary (just not in decimal) unless you want to build your own converter from logic gates (which I do not know how to do?--Tried to find one in examples and public projects--just in case someone had already made one. If I figure one out--I will post it).
04-23-2020 06:27 PM
Would be nice if we had the kind of display that you could just put the binary in.
I went ahead and made a 7-segment display driver using AOI gates.
04-24-2020 09:42 AM
There is another post related to this subject. If thodge has Premium access, seven-segment LED display decoders/drivers are most likely not yet available in Multisim Live. Those 10 LED drivers I cited in my previous reply might be already existing before digital simulation is added to Multisim Live. Thus those are not seven-segment LED display decoders/drivers like 74xx47/8/9.
04-24-2020 11:27 AM
I tried those devices and didn't have any luck.
