The default settings for an LED in Multisim Live don't match normal LED characteristics. I appreciate the ability to adjust the parameters for a given exploratory circuit. But the default should be what is most commonly seen in real life, not something that is not likely to exist.
When my students use a physical LED, the knee voltage is always around 1.5V. The takeaway is, that although it is a diode, not every diode has a .7V knee voltage. In Multisim 14 it is easy for them to see this.
When they use Multisim Live, unless they are given specific instructions on the parameters to change, they will come to the conclusion that all diodes use .7V.
It would be much better to set the default for real life and let the engineers adjust it if needed.
