10-12-2006 11:51 AM
10-13-2006
05:50 PM
- last edited on
03-02-2026
04:21 PM
by
Content Cleaner
Hello leosgb,
Unfortunately, our support for VB5 is quite limited. Does your application require using this older version? If not, I would definetely recommend upgrading. You can download the Visual Basic 2005 Express edition for free at Microsoft's site. With the newer VB you can take advantage of the full functionality of the DAQmx driver. This means that you will be able to sample at 20MHz and also use Measurement Studio to implement pre-built charts and graphs. Here's some potentially helpful documents for you:
NI-DAQmx Support in Visual Basic 6.0
NI-DAQmx Examples for Visual Basic 6.0
Transition from Traditional DAQ to DAQmx in VB.NET
You may be able to get some of the same functionality out of the DAQmx driver in VB5 as you can in VB6 (using the type library); however, we haven't tested this and consequently can't support it. Hopefully upgrading will be a feasible solution for you ![]()
10-13-2006 05:58 PM
