Hello DMBS,
It looks like you are using the DAQPad-6016, which is supported by the
DAQmx driver. The lastest driver for this device can be downloaded from
our website at the following link:
NI-DAQmx Version 8.5 for Windows 2000/Vista x64/Vista x86/XP
Upon installation there are help files that you can select to install
with your driver that will give you information on how to program in C
with the DAQmx Driver. The resource you are looking for is the DAQmx C
Reference Help.
Here are some additional resources to get you started:
How Do I Search for NI-DAQmx Functions, Properties, or Concepts in LabWindows/CVI 7.1 Help?
Using NI-DAQmx in Text Based Programming Environments
I hope this infomation helps. Take a look at these resources and if
your questions isn't answer, please feel free to post here again.
Have a good day!
Sandra T.
Applications Engineer | National Instruments
