Multifunction DAQ
underwater DAQ system
dear all experts,
please guide me to select approriate model of daq board for following requriement for a underwater DAq
Digital data acquisition and storage system
  • Mounted inside the watertight enclosure
  • Robust design and mounting suitable for shipboard handing
  • no of channels: 12
  • Simultaneous sampling, 102.4 k samples/s (or better) per channel
  • 24 bit resolution, dynamic range: ≥ 90 dB
  • Output noise: 1 nV/√Hz at 1 kHz or less
  • Common mode rejection ratio: 100 dB or more
  • Four-level gain selection with minimum 6 dB gain fixed
  • Option of high/ low/ band pass filter and signal bypass facility
  • Frequency selection between 60 Hz and 100 kHz, user selectable with minimum six bands
  • Storage capacity: At least 72 hrs continuous data for 12 channels
  • Hot swappable operation
  • Operating temperature range: 0-70°C or better
 please replay soon.
Advance thanks and regards
Rahul krishnan
krishnarahulrudra@gmail.com
Message 1 of 1
(4,680 Views)
