Multifunction DAQ
trouble select between Differential and RSE
I can measure a differential DC signal using Labwindows/CVI, but I can not measure a ground RSE signal using same.
it works correctly using MAX, where i can select the terminal configuration between differential and RSE as necessary, but i cant get my Labwindows/CVI application to work correctly.  It wants to treat all analog input measurements as differential signals.
thanks in advance for any assistance.
(3,515 Views)
You must have one or more calls to DAQmxCreateAIVoltageChan() (or the equivalent for Labwindows/CVI). That's where the input configuration is set. Show us the call as it appears in your code.
Also- what kind of DAQ device are you using?
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,503 Views)
i guess i'm missing something fundamental.    ive tried a variety of methods; below is excerpt of what i have now.  thanks for your help.
static TaskHandle taskHandle6=0;
int main (int argc, char *argv[])
    int channelnumber=0;
    if (InitCVIRTE (0, argv, 0) == 0)
        return -1;    /* out of memory */
    if ((panelHandle = LoadPanel (0, "test2.uir", PANEL)) < 0)
        return -1;
    DAQmxCreateAIVoltageChan (taskHandle6, "Dev1/ai6", "DUT55C", DAQmx_Val_RSE, -10.0,
                              10.0, DAQmx_Val_Volts, NULL);
    DisplayPanel (panelHandle);
    InitializeSettings ();
    RunUserInterface ();
    DiscardPanel (panelHandle);
    return 0;
int CVICALLBACK DoVoltTest (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
    int32            error=0;
    int                a;
    char            chan[256];
    float64        value;
    char            errBuff[2048]={'\0'};
    if( event==EVENT_COMMIT )
        DAQmxErrChk (Configure_AcqOneSample("DUT55C",0,10,&taskHandle6));
        DAQmxErrChk (Start_AcqOneSample(taskHandle6));
        DAQmxErrChk (Read_AcqOneSample(taskHandle6,&value));
        SetCtrlVal(panel,PANEL_VTEST_6,value);
Error:
    ErrorCheck (error, errBuff, taskHandle6, 3);
    return 0;
(3,496 Views)
oh, and i'm using a NI-DAQmx 6251
if you could just tell me where some examples using this function are, that would probably be just fine.  I seem to be having a rough time sorting through the documentation and examples.
thanks
--Rob
(3,493 Views)
d'oh.
found my problem.    yes, i was missing something very fundamental.
please delete this entire post and hide the evidence of my ignorance.
(3,490 Views)
