10-17-2005 01:37 PM
10-18-2005 03:31 PM
10-18-2005 09:43 PM
10-18-2005 09:59 PM
10-19-2005 06:50 AM
10-20-2005 06:03 PM
Dr. Berns,
I have some answers for you...
"Can you ahve Multiple DAQ Assistant VIs?"
Yes and No. You can have as many as you want as long as they do not confict with each other.
What causes a conflict? Having two different DAQ Assitants accessing the same Analog Input or Analog Output on the same board at the same time. Your most recent program avoids this when doing the Analog Output by making sure the DAQ Assistants do not run at the same time and by not having the DAQ Assistant do continuous task timing.
"Why can I only see 8 signals in the Select Signals Express VI when I want to see all 16?"
There is a Knowledge Base which partially answer this question...
Will the Select Signal Express VI Work With More Than 8 Signals?
The solution in the knowledge base will only work for finite and continuous DAQ Assistant tasks and not single point.
"How is this possible? Does not mean this would also be true for analog inputs?"
What you did in the VI you sent will work. There is another option though. You could group the knob controls together in an array and connect them to the input of one DAQ Assistant which writes to both analog output ports at the same time. Using one DAQ Assistant as opposed to two is cleaner programming in my opinion.
It looks like you are on the right track. Down the road you might want to look into using the lower level DAQmx VIs as opposed to the DAQ Assistant to accomplish your task. The lower level VIs will give you a little bit more flexibility.
I hope this helps,
Lorne Hengst
Application Engineer
