01-23-2006 03:06 PM
01-24-2006 07:54 AM
01-24-2006 01:02 PM
Hi Steve,
Stuart mentioned some interesting points to consider. I would also add that if you are to choose digital outputs you may need additional relays to trigger the solenoids because digital lines have minimal current. Do you have the datasheets on your solenoids? What is the minimum current requirement to trigger the solenoid?
Furthermore, to mitigate the voltage spikes you could try using an RC snubber circuit that suppresses any rapid rise in voltage. This circuit consists of a capacitor in series with a resistor across the solenoid terminals.
We also have numerous signal conditioning modules that specifically handle this type of application. If you would like to post your email I could send you some additional information on system configurations.
Post a message I you need any additional information,
