02-01-2007 07:38 AM
02-01-2007 08:31 AM - edited 02-01-2007 08:31 AM
I think we have a new candidate for Rube Golberg Code.
What you have there simplifies down to this. What exactly are you trying to do? There is no delays or ahny hardware functions in your VI. Does this have anything at all to do with Multifunction DAQ? Do you want to set a software Boolean high for a specific time or a digital ouptut?
Message Edited by Dennis Knutson on 02-01-2007 07:32 AM
02-01-2007 12:42 PM
Hi
I require to generate a digital output when the switch is switched on for a specific period (say 10 seconds). During this time the output shoud go high .After the 10 seconds duration the output should go low ( while the switch is ON). Once this output goes low I require another pulse to generate for 10 seconds which I want to wire to another out put . I have attached a programme on this. It doesn't work properly. I would appreciate if you can modify and help me on this.
Mal
02-02-2007 09:01 AM
02-05-2007 05:48 AM
Hi
Many thanks for the advice. I will try this VI and see how I get on.
Mal
