Multifunction DAQ
reset daq-mxNI-DAQmx API
How can I soft reset the daq-mx, I use TestStand 4.1 with measurement studio?
thanks
greg
(3,796 Views)
Hi greg,
You can rest DAQmx by using: int32 DAQmxResetDevice (const char deviceName[]);DAQmxResetDevice refer to NI-DAQmx C Reference help, it is at the Start menu ... >> National Instruments >> NI-DAQ and look for a topic called 'DAQmxResetDevic' or search for the exact name of the function.
TomBaum
Message Edited by TomBaum on 06-23-2008 10:53 AM
(3,768 Views)
I dont found this function in help, I have version 8.5 of measurement studio
(3,715 Views)
My solution :
Device dev = DaqSystem.Local.LoadDevice(DaqSystem.Local.Devices[0]);
dev.Reset();
Device dev = DaqSystem.Local.LoadDevice(DaqSystem.Local.Devices[1]);
dev.Reset();
(3,709 Views)
Hi greg,
You can also find this file on your disk at C:\Programme\National Instruments\NI-DAQ\docs\cdaqmx.chm or C:\program files\... If you couldn't find it there you haven't installed the complete packages for the driver.
Does any of the suggestion work?
Regards
TomBaum
(3,680 Views)
