Multifunction DAQ
DAQmx Write Overwrite
I have an analog output task.   I wish to buffer(DAQmx Write), Play, and Stop the task several times before task cleanup.   Will the DAQmx Write automatically overwrite any existing DAQmx Write buffers when called?
(2,940 Views)
I'm not sure that I got you right, but what I can say is that everytime the DAQmx write is executed, it will write to the buffer whatever is on that "data"  line.
I hope this will answer your question.
Faris A
Bueller
(2,907 Views)
