Multifunction DAQ
"Skip Count" option in AI Trigger Config.vi does not work
I tried to use the skip count option in AI Config Trigger.vi by setting "skip count" to a value n>0. It showed no effect when used in connection with a digital start & stop trigger, especially in the file AI Start-Stop D-Trig.vi (downloadable from www.ni.com).
I just wanted to scan all the data between the start trigger (=trigger B) and the (n+1)-th stop trigger (=trigger A) by skipping the first n stop triggers.
Is there any trick to solve this problem?
Thanks a lot,
Tobias
(3,051 Views)
Which DAQ card are you using?
Mark
(3,051 Views)
Hi Mark,
I am using a PCI MIO 16E4.
Tobias
(3,051 Views)
Tobias,
Unfortunately, the "skip count" feature is not currently supported by National Instruments DAQ devices. However, the example I have linked to below implements this functionality with the help of a counter.
Event Triggering: Skip a Specified Number of Triggers Before Starting Data Acquisition
Good luck with your application.
Spencer S.
(3,051 Views)
Hi Spencer,
thanks a lot for your hint!
A little problem remains: Counter0 and the AI Start Trigger should start at exactly the same time. Otherwise it may happen that Counter0 already starts counting down while the AI Start Trigger (=triggerB) has missed the start event.
A possible way out might be to make the AI Start Trigger a kind of master which--once it was triggered--immediately starts Counter0. Can this be realized by routing the TRIG1 or STARTSCAN signals to GPCTR0_GATE? If so, how to perform this routing?
Greetings,
Tobias
(3,051 Views)
