Multifunction DAQ
How to connect DAQ6013 with CB-68LPR with 555 timer
I need help to connect the CB-68LPR with 555 timer.
There is only input and a output
The input is V+,V- which is supply by a DC power supply
The output is output of the 555 timer.
(2,909 Views)
Greetings,
Well, this all depends on what you are trying to accomplish. Do you want to measure the frequency of the 555 timer output? Do you want to use this signal as a clock? ETC... Could you provide a little more information concerning your application?
Spencer S.
(2,909 Views)
I trying to have a square analog waveform in the MAX.
Since the 555 timer is the simplest circuit,i build it and try to learn how to connect to the CB-68LPR.Hopely it will have a squre waveform and able to have a digital reading or the red led light up in the MAX.
My circuit is working fine.I tested it with a scope.
My objective is to learn how to use DAQ board.
Then I can use it for my main goal to test ADC and DAC MAXIM chip.
Timer
(2,909 Views)
Timer,
Below, I have included a link to the user manual for the NI 6013. Chapter 4 details the procedures for connecting signals to this device. If you are using the NI 6013 in differential mode, you will connect ACH0 and ACH8 to the circuit from which you want to acquire analog input data. These correspond to terminals 68 and 34 on the CB-68LPR connector block, respectively. ACH0 should be connected to the positive signal, and ACH8 should be connected to the negative signal. After you have made this connection, you should be able to acquire a signal from your circuit with analog input channel 0 in the MAX Test Panel.
NI 6013/6014
User Manual
Spencer S.
(2,909 Views)
