‎10-02-2020 12:26 PM
As you can see the screenshot below, why aggregate multichannel sampling rate is lower than single channel sampling rate?
Solved! Go to Solution.
‎10-04-2020 07:46 PM
You have a device that is muxed. The A/D conversion is shared between all of the channels. You would need a card that has a separate A/D for each channel, like the 6366.
mcduff
‎10-04-2020 10:03 PM
Hi Mcduff,
You didn't get what I mean. Even though sampling rate is shared by channels, but in principle the aggregate rate should be same as maximum single channel rate.
I searched similar question, seems reason is channel needs switching time for multichannels which sacrifice half sampling rate.
‎10-06-2020 09:40 AM
This may be helpful
http://zone.ni.com/reference/en-XX/help/370466Y-01/mxcncpts/multisimulsamp/
