python nidaqmx continous sampling rate
I want to create the python software using NI-DAQmx,
I am using nidaqmx library, But i can't read the DAQ voltage data at Higer sample rate.
Using the same DAQ and Labview it can be read 5MHz.
what is the reson for that, please give me a hint.
It would be really helpful
(1,814 Views)
Clearly, it is your python code which was not implemented properly for continuous capture. What have you tried so far? please share your python code.
I would suggest looking at the example test programs to see where you missed in your implementation.
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(1,813 Views)
import time,threading
import nidaqmx
import matplotlib.pyplot as plt
task = nidaqmx.Task()
task.ai_channels.add_ai_voltage_chan("Dev2/ai0")
task.start()
data = []
class TimerClass(threading.Thread):
    def __init__(self):
        threading.Thread.__init__(self)
        self.event = threading.Event()
        self.count = 0
    def run(self):
        while self.count<200 and not self.event.is_set():
            r = task.read()
            data.append(float(r))
            self.count += 1
            self.event.wait(0.0001)
    def getCount(self):
        self.gtcount = self.count
        self.count = 0
        return self.gtcount
    def stop(self):
        self.event.set()
tmr = TimerClass()
tmr.start()
time.sleep(1)
tmr.stop()
plt.plot(data)
print("Counter Read =  ",tmr.getCount())
plt.show()
____________________________
Output>>>>
Counter Read = 100
this is the simple code for read the higher sampling rate
but the thing is it can't reach the higher sampling rate.
(1,805 Views)
