Multifunction DAQ
problem for generating code module DAQmx Express
I  would like to put a DAMmx Express Moduleto acquire analogics datas, after I configure my module with a simulated signal (input) with MAX I want to generate code from the DAQmx Express but I have an error: (I use a PCI 6221)
"not implemented for this I/O control type"
How Can I resolve this problem???
I would like to know how can I select a signal in the DAQ module, for example I create two simlated signal for the acquisition and I want to select just one signal for viewing it in a graph or use formula module with this signal ect...
Thank you for your help.
bye
(3,027 Views)
- You have not specified what exactly you have setup for your DAQ Assistant. Is it possible to post the VI so we can understand the issue better?
- Search for the Split Signals node in the Express -> Signal Manipulation palette.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,022 Views)
