06-26-2009 12:19 PM
i have a problem of configuration the acquisition card NI 6281, because i don't understand what are the measurement method and if i select the "2 counters (large range or high frequency)", what I have to schedule in labview???
i hope to is clear i this short exposition, and i hope in the response.
thanks you, in anticipation
06-26-2009 01:25 PM
06-28-2009 11:50 AM
thanks you for the response.
yes, i must measurement the frequency of a incremental encoder and
the range of frequency than i use is (0Hz-83Khz). i want understand what method of measurement i must utilize.
i have carried out tests but i have ever problems of sample.
my applicatoin is a calculus of velocity of rotation of a wheel of car, whereby the frequency value is incremental.
could you suggest a method of measurement than i must adapter, and in this case any example.
i see the example of labview, but the problem of the measurement method not is resolved.
thanks in advance
06-29-2009 03:53 AM
and i make configure both the counters for the mesurement a large range (than requires a 2 counters)??
can i change the timebase?? what is he timebase of default??
06-29-2009 04:27 AM
Hi Maurino,
unfortunately there is no definite bandwidth for which you should select either the one or the two-counter method, as you can read here.
As suggested in that document, select Start»All Programs»National Instruments»NI-DAQ»NI-DAQmx Help, and search for 'quantization error': you'll then be able to make a correct choice.
More in general, I suggest you to read the How-to Guide to Frequency Meausurements in DAQmx.
Lucius
06-29-2009 04:48 AM
hi lucuis,
i have see the document in the link.
the method is clear, but in the example tags, my frequency (generate with a function generation) while keeping costant, in my measurement application is variant.
and i don't understand the because
06-29-2009 09:19 AM
Hi Maurino,
what do you mean with "variant"? which is the difference between an acquisition and the other? how's your signal made?
I am asking that because the examples are correct and if you have followed the instruction written in the document I suggested you, you should have no problem.
Lucius
06-29-2009 10:02 AM
hi lucius,
my signal have original from acceleration of a car. i have modificated the exemple clearing the TIMING ICON, and this action is succesfull.
whereby seems to work for now.
i have an other problem: in the timed loop the period is the time between 1 iteration and other???
thanks you very much for your help
06-30-2009 02:44 AM
Hi Maurino,
you're right.
Lucius
