Multifunction DAQ
ph_exec
Dear Friends
Hi
I'm new in this field but , recently I recived a new system cDAQ9138 with NI signal express software and CDaq driver DVD.
Generaly every thing should be very straight-forward to work with , after installing NI Signal epxress and CDaq driveres I tried to
make my frist measurments.
but!! unfrotunately my CDAq system after bootup showes below erorr message ( I have attached a monitor to VGA output of CDaq9138)
Unable to find boot program c:\ph_exec.exe booting into Safe Mode
So I am stock here and dont know what should be done .
Basicaly I know that system should come with Labview RT install on it and i just connect the PC to it and use NI Signal express to work with it .
I would really appricate if any of you advise how to fix this.
Ron
(5,635 Views)
Hi Ron,
It sounds like you've made it most of the way to taking your measurement, but there's one more step.  After installing drivers on your host machine, you need to push that software onto the cDAQ controller.  This RT Quick Start guide should get you through the rest of the setup -- you are on step 8.  Let us know if you run into any other speedbumps.
(5,602 Views)
