Multifunction DAQ
pci6221 accessory
Hi
I'm going to buy a NI PCI-6221 (part number:779418-01) card, I had questions about its accessories.
1- The terminal CB-37F-LP (part number:779353-01) can be connected to the NI PCI-6221 card directly without a cable.
(2,401 Views)
@seied64 wrote:
Hi
You would need a cable for any of the accessories/terminal blocks for the card.
But the accessory page for the PCI-6221 does not list the CB-37F-LP as an option.  So I am not sure if there is a cable to connect them.  But if you call NI they can guide you through getting the correct parts.
https://www.ni.com/sic/configurator/configure.action?sfId=NI&wcs_l=en-us&wcs_k=multifunction-io-devi...
(2,337 Views)
Hello seied64,
In the INSTALLATION GUIDE of NI CB-37F-LP on page 5 - 6 you can see that both variants are possible.
So yes, it is possible to connect NI CB-37F-LP connector block to NI PCI-6221 (part number:779418-01) module without cable directly.
__________________________________________
The best way to thank, is to give KUDOS
(2,312 Views)
