Hi I'm going to buy a NI PCI-6221 (part number:779418-01) card, I had questions about its accessories. 1- The terminal CB-37F-LP (part number:779353-01) can be connected to the NI PCI-6221 card directly without a cable.
You would need a cable for any of the accessories/terminal blocks for the card.
But the accessory page for the PCI-6221 does not list the CB-37F-LP as an option. So I am not sure if there is a cable to connect them. But if you call NI they can guide you through getting the correct parts.
