Multifunction DAQ
pci-6713 analog out signal is generated sometime not in some time
Hello
i am using pci6713 to generate crnk and cam signal(pulse stream ) . I have a two vi with two different max configuration, my problem is that, when i switch on the system and load the MAX configuration and run the vi analog (crk ,cam ) signal is not generating but when I remove the card from pci slot and inserted again  and run the vi   10  or more time then I will get the  analog signal . After loading max configuration I am resetting the board and self testing in vi before generating crk and cam signal generation  .what would be the problem I am using sbc68 type connector .the counter present in the card is working no need to remove the card for counter operation
Message 1 of 1
(3,020 Views)
