Multifunction DAQ
opening data file created with 'Write File'
I was in the field collecting data with 'Acquire N Scans Analog Hardware Trig.vi' and realized that I needed to save the data to a file.  I quickly added a 'Write File' and saved the data.  Now, however, I am not able to open the files that I created.  I've tried many things with 'Read File' and the 'Read Data' VI without any success.
Attached are the VI that I used and a resulting data file.  Any help would be greatly appreciated.
hardware: DAQPad 6070E
software: LabVIEW 7.1
VI Settings: 1 channel; number of scans to acquire = 300,000; scan rate = 625,000; pretrigger scans = 10,000
(3,595 Views)
The modifications in this attached VI  will save data as an ascii file
but for such a larger scan rates and higher sample count, i would recommend file saving in Binary file format.
Go to examples>>hardware  input output>>DAQmx>.analog measurements >voltage >>cont acq&graph volt-to file(bin).vi and read data using graph acquired binary data
For traditional DAQ VI's, examples>>hardware  input output>>Traditional DAQ>>stream to disk examples
These should serve your purpose better
Regards
Dev
(3,577 Views)
Regards
Dev
(3,577 Views)
ewestman,
Thanks for posting to the NI Forums.  I was able to read the data from the file you attached.  Reading the data requires passing the read binary file vi the waveform data type (which I did as a constant in the attached example.)  Let me know if you have any questions.
Neil S.
(3,567 Views)
With your help I'm able to read the files now -
many thanks,
Erik
(3,533 Views)
