08-08-2006 07:32 AM
08-08-2006 12:08 PM
08-08-2006 01:55 PM
I am using Labwindows/CVI 8.01
I am using this sequence:
framesize=8192(works OK) or 131072
status = ScaledWindowEx(distored_signal, framesize, window_type,0.0, &winConst);
status = AutoPowerSpectrum (distored_signal, framesize, 1/rate, spectrum,&spec_freq);
status += SpectrumUnitConversion (spectrum, framesize/2, 0, 0, 0, spec_freq, winConst, conSpectrum, units);
HarmonicAnalyzer (spectrum, framesize/2, 0, number_of_harmonics, window_type,
rate, fundamental_freq, harmonic_amplitudes, harmonic_frequencies, &thd,
&thdNoise);
"weird" = when I use 131072 the freq per bin in conSpectrum=spec_freq but if I multiply bin_number*spec_freq it does not equal the expected frequency in the test signal. The bin count is low by about 25 bins.
Actuall I see the weird behaviour is in function SpectrumUnitConversion not HarmonicAnalyzer
