Multifunction DAQ
openSuse11.2 LabVIEW caught fatal signal 10.0 - Received SIGSEGV Reason: invalid permissions for mapped object
I get an error when trying to launch a jni wrapper for NIDAQmxBase for USB-6009 device:
With NIDAQmxBase3.4 I get:
Attempt to reference address: 0x0xb7655890
I'm running NIDAQmxBase 3.4 now, but the same error with different Labview number occured with NIDAQmxBase 3.3, both on openSuse11.2.
With NIDAQmxBase 3.3, even the examples didn't work after that:
8.2.1 - Received SIGSEGV
Attempt to reference address: 0xb7648890
./acquireNScans
Reason: address not mapped to object
Speicherzugriffsfehler
That's why I switched back to 3.4 although createTask() takes very long.
This happens exactly when I call (from shared object, generated from cpp file)
DAQmxBaseCreateTask("",&taskHandle));
When I run the same method from a c++ project, whether as standalone application or as dynamic library, everything works fine.
The jni methods also work, when I don't call any methods from nidaqmxbase. As soon as a nidaqmxbase method is called I get these errors.
Message 1 of 9
(6,146 Views)
I had to link the cpp part of the jni-project with -lnidaqmxbase -lniCPULib, otherwise  it would compile, but when running the java part it compains:
Unable to load libniCPULib.so from /usr/local/lib/LabVIEW-2010/libniCPULib.so
 As c++ project, the same program compiles and runs perfectly with -lnidaqmxbase, but also with -lniCPULib. I'm really confused. In short terms:
-program works as standalone and as shared object, when c++ only.
-works as jni, without nidaqmxbase method calls.
Message 2 of 9
(6,140 Views)
HI MTer,
I'm not really able to help you. Have you seen these two links:
http://digital.ni.com/public.nsf/allkb/802A9D349090D3F5862565CC0076BCF9
http://forums.ni.com/t5/Measurement-Studio-for-VC/DAQmx-with-C-JNI-Java/m-p/856754?requireLogin=Fals...
As I understand you you can call the DAQmx functions compiled as a so from a C++ program, but not from a Java program?
Best Regards,
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
Message 3 of 9
(6,111 Views)
Thx,
but the links only show the steps, I already have made.
Except that I try to call DAQmxBase functions, that's right. To be more specific, the DAQmxBase functions are called from C++ files in both cases:
Method from CppWrapper.cpp, called from Java, produces the error:
JNIEXPORT jboolean JNICALL Java_JavaWrapper_createTask
(JNIEnv *env, jobject obj)
DAQmxBaseCreateTask("",&taskHandle);
return true;
Same method without DAQmxBaseCreateTask (..) from CppWrapper.cpp, called from Java, produces no error:
//      DAQmxBaseCreateTask("",&taskHandle);
      cout<<"I'm fine"<<endl;
      return true;
Same method from COnlyDyn.cpp without JNI stuff, called from another C++ program also works:
bool createTask()
      return true;
I attached the clean and build outputs and an error log, maybe someone can find a mistake there.
Message 4 of 9
(6,091 Views)
To make confusion perfect:
Under Windows, the whole JNI-Wrapper works as expected, but only using Microsoft visual Compiler, but that's another story, I'll put that in another thread. The program itself doesn't seem to cause this error but the NIDAQmxBase driver for linux. Please tell me if I can help you debugging this.
Message 5 of 9
(6,037 Views)
Did you play around with the linking order, maybe thats the trick. That's all I can help you.
Andreas Stark
Message 6 of 9
(6,019 Views)
MTer,
Did you ever figure this out? I'm running into the same message when calling a custom built .so from LabVIEW on Linux as well... Just curious if you ever found a solution.
Message 7 of 9
(5,701 Views)
I have a similar issue when running 'gpibtst' ...
gpibtst gui crashes with :
Bit frustrating why? how? without any resouces from NI. It appears NI developers and Big Physics group clueless for days.
8.5.1 - Received SIGSEGV
1. my OS is RHEL 6.3 (32 bit)
2. I increased the default stack  to 16K :
stack size              (kbytes, -s) 16384
3. I reduced the RAM count < 4096M  in grub by setting "mem=3072M"
4. I also set the SELinux to permissive mode:
sestatus:
SELinux status:                 enabled
SELinuxfs mount:                /selinux
Current mode:                   permissive
Mode from config file:          enforcing
Policy version:                 24
Policy from config file:        targeted
Message 8 of 9
(5,293 Views)
Here is my testing environment:
sestatus:
Policy version:                 24
Bit frustrating why? how? without any resources from NI. It appears NI developers and Big Physics group clueless for days.
Message 9 of 9
(5,289 Views)
