myDAQ encoder sample rate
May you share with me your VI? Then I can see how you've configured it.
Plínio Costa
Senior Techinical Support Engineer
National Instruments Brazil
Message 11 of 15
(1,545 Views)
Here you are! Thank you!
Message 12 of 15
(1,538 Views)
Accepted by topic author thiago.barbosa
What is causing this "unexpected'" timing is the function Simulate Signal2 (DC signal), you are using a frequency of 100 Hz and a number of samples equal to 100, which forces iteration period of 1s. Try to change it to the same of the other Simulate signal function.
It is very important to understand the relationship between both parameters in every aquisition or generation function in LabVIEW and which loop timing it will cause. If you ask the function to generate 100 samples per second and ask it to return 100 samples per iteration, the iteration will take 1s to execute.
Plínio Costa
Message 13 of 15
(1,515 Views)
Working perfectly now. Thank you.
Message 14 of 15
(1,470 Views)
Great to hear it worked, Thiago
Plínio Costa
Message 15 of 15
(1,467 Views)
