Multifunction DAQ
multiple DAQ (LAb-PC+ and AT-MIO-16E-10)
Hi, right now I have a little problem, that is: How can I install simultaneously on the same computer the LAB-BC+ and AT-MIO-16E-10 boards (on a computer running XP, win2000 or NT)? Thank you very much.
(2,846 Views)
Marius,
Just to clarify what is the “little problem” that you run into? Some things that you might not have come across. The last OS that has support for the NI Lab-PC+ was Windows 2000, or NT. The “newest” driver that supports that card is 6.9.3, which you can see here. The AT-MIO-16E-10 is a bit newer, but to use both of them, you will be limited by the Lab-PC+.
So that would be the setup you would have to go with, though using 6.9.3 drivers may limit you depending on which development environment you can use. For instance the last version of LabVIEW to support those drivers is LabVIEW 6.1. So depending on your situation, it may be a good time to look at upgrading your hardware to something newer. Any way, I hope that helps, let us know if you have any other questions.
-GDE
(2,833 Views)
