Multifunction DAQ
measure and generate using USB6356.
    I want to generate analog signals using my usb6356, but dont have an oscilliscope to verify if the signal is being generated correctly. Is it ok if I use onf of the cards analog inputs to simultaneously acquire the generated signal?
Some one did something like this previously http://forums.ni.com/t5/Multifunction-DAQ/generate-a-sinewave-and-acquire-it-at-the-same-time-to-mea... so I guess this mught be ok aswell.
Umar Khan.
(2,925 Views)
Sure you can loop it back.
(2,919 Views)
