Multifunction DAQ
max database corrupted at every startup
On a computer running under Win XP and with several older LabView versions installed (7.1, 8.5, 8.5.1, 2009) I installed LabVIEW 2010 including the device drivers from August 2010 / DAQmx 9.2.1.
Since then, the Measurement & Automation Explorer is having problems: when being started, it stalls in the state "Initialising" for several minutes. When it is finally started, it does not respond to user input and gives a message indicating an error when connecting to the database.
After deleting the MAX database (see http://digital.ni.com/public.nsf/websearch/86256F0E001DA9FF86256FFD005B827C?OpenDocument) and restarting the computer, MAX working properly. However, after having working with my LabVIEW application and shutting down / restarting the computer, the same problem with a stalling MAX occurs again.
So, as I interpret it, the MAX database is corrupted again after everytime I have deleted it.
I attached the files of the MAX "last" and "data" folder, as described in the link above.
What could I do to solve this problem permanently?
(3,436 Views)
I'm not certain if this is related, but 9.1 to 9.2.1 had some issues with database corruption, there is a patch, see here:
http://forums.ni.com/t5/Multifunction-DAQ/Patch-Released-for-NI-DAQmx-To-Address-an-Issue-Where-Devi...
-AK2DM
(3,424 Views)
Hi There,
this is s a bit weird, normally if you resolve the corruption it should work again properly.
Check out this tool if it helps:
http://decibel.ni.com/content/docs/DOC-12805
Greetings, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,392 Views)
