Multifunction DAQ
load cell
I have a load cell, I wanted to know how can I read it through NI-USB 6212 DAQ card?
(4,810 Views)
I have a key.... how do I drive my car??? 😄
What type of load cell??
usually a look in the user manual tell you how to connect it right 😉
MAX create channel assistant can help, RTFM can help
Greetings from Germany
Henrik
LV since v3.1
(4,796 Views)
Thank you for your reply,
I am using a LLB130 FUTEK miniature loadcell. It used o be USBbut I have cut the wire and connect Sig+ and Sig- to one BNC cable and Exc+and EXc- to another BNC cable. I attached the Exc BNC to USER terminal (5 V) and the signal cable to one of the analogue input of the DAQ card. I tried Analog input (voltage) VI  in labview it didnt work. I woud be thanful if you help me that hw can I read and process the signal in labview.
Omid
(4,754 Views)
Read the user manual book all information are there you can e asily get all necessary information about your loadcell from there. Working techniques of load cells of different manufacturing companies are different.
(4,481 Views)
