Multifunction DAQ
linear encoder count doubles going reverse than forward
I have a quadrature linear encoder. I hooked it up with a PCI-MIO-16E-4 (aka PCI-6040E) according to the tutorial. Forward motion works great. But reverse motion have decrementation twice as much as it should. I have it hook as: A to PFI8, B to DIO6 and using counter 0. Can anyone please tell me what is wrong? Thanks alot!
Famus
(3,113 Views)
Hi Famus
Using quadrature encoder with PCI (i.e. not cDAQ) use connect Channel A to the source input of counter x (coutner 0) which is PFI8 as you said.
However, for B, you need to connect to the up/down line - im not sure if its DIO6. But check your connections and make sure you set the counter for simple edge counting and set the active edge to falling.
link - about your set up - maybe its vibrations?
Please reply soon,
Regards
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,100 Views)
Hello Famus,
Thanks for your post!
I would like to ask if you are using digital lines 0-5 while also trying to use your encoder on line 6? If this is the case there might be a setting you will have to change to make this work correctly. Its not the same exact behavior but take a look at the following knowledge base that talks about this issue.
Using the Open Digital Lines on an E-Series DAQ Board when Taking Encoder Measurements
Let us know if any of this information helps you with your problem!
Cheers!
Corby_B
http://www.ni.com/support
(3,094 Views)
