Multifunction DAQ
applicatie
What does TestStand with a LabView Modules and the vi's that are being used in these modules after making a UI in LabView and making an application of this UI with LV application builder. I'm going a bit mad because when I running the UI in Labview thers is no problem but after I make this UI an application TestStand give me Call's that I can't understand, For example 'can't find a parameter in the VI's connector pane'. This is all happening on one and te same computer so there are no changes in directories or whatever. I you have a clue please let me know.
Thanx,
Dennis
Message 1 of 1
(2,709 Views)
