labview load error code 21
I am trying to run a Labview exe created in 5.1 into daq legacy to record a signal from a bnc 2120 daq device with a pci 6034.  I have tried a combination of different drivers and keep getting the load error code 21.  What applications and drivers to I need to run this setup in windows 7?
thanks,
zach
(3,785 Views)
You need a version of LabVIEW and a DAQ driver that is supported on windows 7. LabVIEW 5.1 is not and there is no version of traditional DAQ that is supported.
(3,780 Views)
Hi Zach,
Here's a link to a list of the officially supported LabVIEW/Windows compatible versions. A LabVIEW 5.1 executable will likely not be able to run on a Windows 7 machine. You could try to upgrade your code and recompile your executable in a later version of LabVIEW.
Rohan B
(3,750 Views)
