labview hangs when run program
when i run a daq application program after one or two runs labview window hangs
(2,685 Views)
Could you please give me more insight into your problem? To start: What version of Labview are you using? What hardware are you using? What is your program doing? When the program hangs, does it give an error message?
With this information, I might be able to help. Another alternative is calling/emailing NI for support. If you have not used your 30 day trial of support you may want to try this.
(2,685 Views)
