inductive proximity sensor with DAQ
SOLVED
rodeo87
Member
Message contains an attachment
Hi everyone
I am planing to connect my inductive proximity sensor with NI-9215 DAQ but not sure will that thing work perofectly. Also i don't know how to connect my sensor with the BNC terminal.
The sensor I am using is from automation direct AM9-05-1A with input volatage of 10-30 VDC and output voltage range from 0-5 VDC.
I want DAQ to monitor my output signal from sensor.
5 REPLIES 5
johnsold
Knight of NI
Re: inductive proximity sensor with DAQ
What DAQ device are you using? What is the BNC "terminal" connected to?
It appears that the sensor comes with a 4-conductor connector. Two pins will need to connect to a power supply. Two pins will connect to the DAQ input. One of the two pins in each case is the ground, common, or L- pin.
Lynn
rodeo87
Member
Message contains a hyperlink
Hey lynn
I am planing to use NI-9215 DAQ. Here is the link for that.
https://www.ni.com/en-us/shop/model/ni-9215.html
Since this kind of DAQ has BNC type of connectivity with it so I am not sure how to connect my sensor with this connector.
rodeo87
Member
I have cDAQ - 9174 with me as chassis option
johnsold
Knight of NI
It appears that you have two choices.
1. Cut the connector off the sensor and wire the appropriate conductors to a piece of coaxial cable with a BNC plug (and separately to the power supply).
or
2. Get a jack which matches the plug on the sensor cable and wire its terminals to a coaxial cable with BNC plug and to the power supply.
Lynn
rodeo87
Member
Thanks Lynn
