Multifunction DAQ
取消
顯示結果
搜尋替代
您的意思是:
how to use CONTEC AIO boards in NI MAX
What's need to do to use CONTEC aio boards in NI MAX
0 積分
1 條訊息(共 8 條)
4,956 檢視
MAX is only for NI DAQ cards. Didn't the vendor provide its own utility?
0 積分
2 條訊息(共 8 條)
4,952 檢視
Thank your reply.
I am a CONTEC software engineer. The user want to use CONTEC cards such as AIO, DIO in NI MAX.
I would appreciated it if you can tell me the solution.
0 積分
3 條訊息(共 8 條)
4,944 檢視
Your card would have to use the DAQmx driver. Since it doesn't, it cannot be recognized by MAX.
0 積分
4 條訊息(共 8 條)
4,939 檢視
Dennis,
I think it's possible as you pointed out back in 2010 on this thread.
Tony,
Look at the NI-VISA Driver Wizard. You can use this to get some third party hardware to appear in MAX. Hope this helps.
I don't think you will be able to get all the features that you would from a NI device, but you should have access to VISA Test Panels to control the device.
Aaron W.
CLA, CTA and CPI
0 積分
5 條訊息(共 8 條)
4,932 檢視
But as anyone who has used the driver wizard can tell you, the wizard removes the vendor's driver so all of the device functions have to be rewritten from scratch.
I've seen the wizard recommended time after time and the user often ends up with nothing.
0 積分
6 條訊息(共 8 條)
4,928 檢視
Valid point.
But he's the software engineer for CONTEC, so he seems like the right person for the job. 😉
Aaron W.
CLA, CTA and CPI
0 積分
7 條訊息(共 8 條)
4,925 檢視
Unless the end user wants to use the DAQ functions in MAX such as the test panels, create tasks, etc.
0 積分
8 條訊息(共 8 條)
4,922 檢視
