how to save the AO signal using DAQmx Logging?
Hi all,
I can save the AI signal using "DAQmx Logging". However, there are errors when I use "DAQmx Logging" with AO task. Could any body tell me how to correctly save the AO signal in a similar way?
best
(4,119 Views)
I hope the saving process happends outside of the while loop, so that it can save a lot of processing time.
(4,118 Views)
What I have always done is use another analog input that is sensing the analog output.  The AI can then be logged using the DAQmx Configure Logging.
GCentral
(4,103 Views)
