Multifunction DAQ
how to resolve the errors 134013003!
Problem: I am running some of the NI-DAQmx Base examples for Pocket PC and am receiving error code 130413003, unable to lock memory chunk.
Solution: This problem can be caused when changes are made to the development machine's Windows operating system properties such as the font, color scheme, or language. When using the NI-DAQmx Base driver, only ESeries AI Read FIFO Raw 1D I16 Pretrigger.vi and ESeries AI Read FIFO Raw 1D I16.vi are affected by this problem. Therefore, if you receive this error, you should open these VIs, place a VI on the block diagram then delete the VI you placed on the block diagram. Basically, when an item is placed on the block diagram, this triggers LabVIEW to examine all wires and prototypes and the type mismatch caused by the property change on the Windows development machine will be corrected.
This issue will be fixed in a future version of the NI-DAQmx Base driver.
Message 1 of 1
(2,706 Views)
