Multifunction DAQ
DAQmx 7.4 unrecognize PCI 6025
hello
I install DAQ 7.4 on computer and the DAQmx unrecognize the PCI 6025 card.
The Traditional DAQ work properly.
eran
(3,315 Views)
You will probably just want to re-install NI-DAQmx.  I would recommend removing the device, uninstalling NI-DAQ, the re-installing NI-DAQmx from the here.  Then putting your device back in your machine (with it turned off, of course), rebooting and following the Windows install wizard.  Re-post if that doesn't work.
-Alan A.
(3,297 Views)
